CesiumGltfReader::ExtensionKhrImplicitShapesBoxReader Class Reference
Reads ExtensionKhrImplicitShapesBox instances from JSON. More...
#include <CesiumGltfReader/ExtensionKhrImplicitShapesBoxReader.h>
 ExtensionKhrImplicitShapesBoxReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrImplicitShapesBox > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionKhrImplicitShapesBox from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrImplicitShapesBox > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionKhrImplicitShapesBox from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrImplicitShapesBox > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionKhrImplicitShapesBox from a rapidJson::Value.
Definition at line 25 of file ExtensionKhrImplicitShapesBoxReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrImplicitShapesBox > > CesiumGltfReader::ExtensionKhrImplicitShapesBoxReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrImplicitShapesBox > CesiumGltfReader::ExtensionKhrImplicitShapesBoxReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrImplicitShapesBox > CesiumGltfReader::ExtensionKhrImplicitShapesBoxReader::readFromJson ( const std::span< const std::byte > & data) const
