CesiumGltfReader::ExtensionKhrGaussianSplattingReader Class Reference
Reads ExtensionKhrGaussianSplatting instances from JSON. More...
#include <CesiumGltfReader/ExtensionKhrGaussianSplattingReader.h>
 ExtensionKhrGaussianSplattingReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrGaussianSplatting > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionKhrGaussianSplatting from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrGaussianSplatting > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionKhrGaussianSplatting from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrGaussianSplatting > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionKhrGaussianSplatting from a rapidJson::Value.
Definition at line 25 of file ExtensionKhrGaussianSplattingReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrGaussianSplatting > > CesiumGltfReader::ExtensionKhrGaussianSplattingReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrGaussianSplatting > CesiumGltfReader::ExtensionKhrGaussianSplattingReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrGaussianSplatting > CesiumGltfReader::ExtensionKhrGaussianSplattingReader::readFromJson ( const std::span< const std::byte > & data) const
