cesium-native 0.62.0
CesiumGltfReader::ExtensionKhrGaussianSplattingHintsValueReader Class Reference
Reads ExtensionKhrGaussianSplattingHintsValue instances from JSON. More...
#include <CesiumGltfReader/ExtensionKhrGaussianSplattingHintsValueReader.h>
 ExtensionKhrGaussianSplattingHintsValueReader ()
CesiumJsonReader::JsonReaderOptionsgetOptions ()
const CesiumJsonReader::JsonReaderOptionsgetOptions () const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrGaussianSplattingHintsValuereadFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionKhrGaussianSplattingHintsValue from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrGaussianSplattingHintsValuereadFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionKhrGaussianSplattingHintsValue from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrGaussianSplattingHintsValue > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionKhrGaussianSplattingHintsValue from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrGaussianSplattingHintsValue > > CesiumGltfReader::ExtensionKhrGaussianSplattingHintsValueReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrGaussianSplattingHintsValue > CesiumGltfReader::ExtensionKhrGaussianSplattingHintsValueReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrGaussianSplattingHintsValue > CesiumGltfReader::ExtensionKhrGaussianSplattingHintsValueReader::readFromJson ( const std::span< const std::byte > & data) const
