CesiumGltfReader::ExtensionKhrDracoMeshCompressionReader Class Reference
Reads ExtensionKhrDracoMeshCompression instances from JSON. More...
#include <CesiumGltfReader/ExtensionKhrDracoMeshCompressionReader.h>
 ExtensionKhrDracoMeshCompressionReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrDracoMeshCompression > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionKhrDracoMeshCompression from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrDracoMeshCompression > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionKhrDracoMeshCompression from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrDracoMeshCompression > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionKhrDracoMeshCompression from a rapidJson::Value.
Definition at line 25 of file ExtensionKhrDracoMeshCompressionReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionKhrDracoMeshCompression > > CesiumGltfReader::ExtensionKhrDracoMeshCompressionReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrDracoMeshCompression > CesiumGltfReader::ExtensionKhrDracoMeshCompressionReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionKhrDracoMeshCompression > CesiumGltfReader::ExtensionKhrDracoMeshCompressionReader::readFromJson ( const std::span< const std::byte > & data) const
