CesiumGltfReader::ExtensionExtStructuralMetadataReader Class Reference
Reads ExtensionExtStructuralMetadata instances from JSON. More...
#include <CesiumGltfReader/ExtensionExtStructuralMetadataReader.h>
 ExtensionExtStructuralMetadataReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtStructuralMetadata > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionExtStructuralMetadata from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtStructuralMetadata > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionExtStructuralMetadata from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtStructuralMetadata > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionExtStructuralMetadata from a rapidJson::Value.
Definition at line 25 of file ExtensionExtStructuralMetadataReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtStructuralMetadata > > CesiumGltfReader::ExtensionExtStructuralMetadataReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtStructuralMetadata > CesiumGltfReader::ExtensionExtStructuralMetadataReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtStructuralMetadata > CesiumGltfReader::ExtensionExtStructuralMetadataReader::readFromJson ( const std::span< const std::byte > & data) const
