CesiumGltfReader::ExtensionExtPrimitiveVoxelsReader Class Reference
Reads ExtensionExtPrimitiveVoxels instances from JSON. More...
#include <CesiumGltfReader/ExtensionExtPrimitiveVoxelsReader.h>
 ExtensionExtPrimitiveVoxelsReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtPrimitiveVoxels > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionExtPrimitiveVoxels from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtPrimitiveVoxels > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionExtPrimitiveVoxels from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtPrimitiveVoxels > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionExtPrimitiveVoxels from a rapidJson::Value.
Definition at line 25 of file ExtensionExtPrimitiveVoxelsReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtPrimitiveVoxels > > CesiumGltfReader::ExtensionExtPrimitiveVoxelsReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtPrimitiveVoxels > CesiumGltfReader::ExtensionExtPrimitiveVoxelsReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtPrimitiveVoxels > CesiumGltfReader::ExtensionExtPrimitiveVoxelsReader::readFromJson ( const std::span< const std::byte > & data) const
