CesiumGltfReader::ExtensionExtNodeVisibilityVolumeReader Class Reference
Reads ExtensionExtNodeVisibilityVolume instances from JSON. More...
#include <CesiumGltfReader/ExtensionExtNodeVisibilityVolumeReader.h>
 ExtensionExtNodeVisibilityVolumeReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtNodeVisibilityVolume > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionExtNodeVisibilityVolume from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtNodeVisibilityVolume > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionExtNodeVisibilityVolume from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtNodeVisibilityVolume > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionExtNodeVisibilityVolume from a rapidJson::Value.
Definition at line 25 of file ExtensionExtNodeVisibilityVolumeReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtNodeVisibilityVolume > > CesiumGltfReader::ExtensionExtNodeVisibilityVolumeReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtNodeVisibilityVolume > CesiumGltfReader::ExtensionExtNodeVisibilityVolumeReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtNodeVisibilityVolume > CesiumGltfReader::ExtensionExtNodeVisibilityVolumeReader::readFromJson ( const std::span< const std::byte > & data) const
