CesiumGltfReader::ExtensionExtMeshPolygonReader Class Reference
Reads ExtensionExtMeshPolygon instances from JSON. More...
#include <CesiumGltfReader/ExtensionExtMeshPolygonReader.h>
 ExtensionExtMeshPolygonReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtMeshPolygon > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionExtMeshPolygon from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtMeshPolygon > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionExtMeshPolygon from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtMeshPolygon > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionExtMeshPolygon from a rapidJson::Value.
Definition at line 25 of file ExtensionExtMeshPolygonReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtMeshPolygon > > CesiumGltfReader::ExtensionExtMeshPolygonReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtMeshPolygon > CesiumGltfReader::ExtensionExtMeshPolygonReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtMeshPolygon > CesiumGltfReader::ExtensionExtMeshPolygonReader::readFromJson ( const std::span< const std::byte > & data) const
