CesiumGltfReader::ExtensionExtMeshGpuInstancingReader Class Reference
Reads ExtensionExtMeshGpuInstancing instances from JSON. More...
#include <CesiumGltfReader/ExtensionExtMeshGpuInstancingReader.h>
 ExtensionExtMeshGpuInstancingReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtMeshGpuInstancing > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionExtMeshGpuInstancing from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtMeshGpuInstancing > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionExtMeshGpuInstancing from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtMeshGpuInstancing > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionExtMeshGpuInstancing from a rapidJson::Value.
Definition at line 25 of file ExtensionExtMeshGpuInstancingReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtMeshGpuInstancing > > CesiumGltfReader::ExtensionExtMeshGpuInstancingReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtMeshGpuInstancing > CesiumGltfReader::ExtensionExtMeshGpuInstancingReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtMeshGpuInstancing > CesiumGltfReader::ExtensionExtMeshGpuInstancingReader::readFromJson ( const std::span< const std::byte > & data) const
