Reads ExtensionExtInstanceFeaturesFeatureId instances from JSON. More...
#include <CesiumGltfReader/ExtensionExtInstanceFeaturesFeatureIdReader.h>
| ExtensionExtInstanceFeaturesFeatureIdReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtInstanceFeaturesFeatureId > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of ExtensionExtInstanceFeaturesFeatureId from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtInstanceFeaturesFeatureId > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of ExtensionExtInstanceFeaturesFeatureId from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtInstanceFeaturesFeatureId > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of ExtensionExtInstanceFeaturesFeatureId from a rapidJson::Value. | |
Definition at line 25 of file ExtensionExtInstanceFeaturesFeatureIdReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtInstanceFeaturesFeatureId > > CesiumGltfReader::ExtensionExtInstanceFeaturesFeatureIdReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtInstanceFeaturesFeatureId > CesiumGltfReader::ExtensionExtInstanceFeaturesFeatureIdReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtInstanceFeaturesFeatureId > CesiumGltfReader::ExtensionExtInstanceFeaturesFeatureIdReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
