CesiumGltfReader::ExtensionExtImplicitEllipsoidRegionReader Class Reference
Reads ExtensionExtImplicitEllipsoidRegion instances from JSON. More...
#include <CesiumGltfReader/ExtensionExtImplicitEllipsoidRegionReader.h>
 ExtensionExtImplicitEllipsoidRegionReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtImplicitEllipsoidRegion > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionExtImplicitEllipsoidRegion from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtImplicitEllipsoidRegion > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionExtImplicitEllipsoidRegion from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtImplicitEllipsoidRegion > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionExtImplicitEllipsoidRegion from a rapidJson::Value.
Definition at line 25 of file ExtensionExtImplicitEllipsoidRegionReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtImplicitEllipsoidRegion > > CesiumGltfReader::ExtensionExtImplicitEllipsoidRegionReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtImplicitEllipsoidRegion > CesiumGltfReader::ExtensionExtImplicitEllipsoidRegionReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtImplicitEllipsoidRegion > CesiumGltfReader::ExtensionExtImplicitEllipsoidRegionReader::readFromJson ( const std::span< const std::byte > & data) const
