CesiumGltfReader::ExtensionExtImplicitCylinderRegionReader Class Reference
Reads ExtensionExtImplicitCylinderRegion instances from JSON. More...
#include <CesiumGltfReader/ExtensionExtImplicitCylinderRegionReader.h>
 ExtensionExtImplicitCylinderRegionReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtImplicitCylinderRegion > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionExtImplicitCylinderRegion from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtImplicitCylinderRegion > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionExtImplicitCylinderRegion from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtImplicitCylinderRegion > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionExtImplicitCylinderRegion from a rapidJson::Value.
Definition at line 25 of file ExtensionExtImplicitCylinderRegionReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtImplicitCylinderRegion > > CesiumGltfReader::ExtensionExtImplicitCylinderRegionReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtImplicitCylinderRegion > CesiumGltfReader::ExtensionExtImplicitCylinderRegionReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtImplicitCylinderRegion > CesiumGltfReader::ExtensionExtImplicitCylinderRegionReader::readFromJson ( const std::span< const std::byte > & data) const
