CesiumGltfReader::ExtensionExtGeospatialCrsWkt2Reader Class Reference
Reads ExtensionExtGeospatialCrsWkt2 instances from JSON. More...
#include <CesiumGltfReader/ExtensionExtGeospatialCrsWkt2Reader.h>
 ExtensionExtGeospatialCrsWkt2Reader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtGeospatialCrsWkt2 > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionExtGeospatialCrsWkt2 from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtGeospatialCrsWkt2 > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionExtGeospatialCrsWkt2 from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtGeospatialCrsWkt2 > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionExtGeospatialCrsWkt2 from a rapidJson::Value.
Definition at line 25 of file ExtensionExtGeospatialCrsWkt2Reader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtGeospatialCrsWkt2 > > CesiumGltfReader::ExtensionExtGeospatialCrsWkt2Reader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtGeospatialCrsWkt2 > CesiumGltfReader::ExtensionExtGeospatialCrsWkt2Reader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtGeospatialCrsWkt2 > CesiumGltfReader::ExtensionExtGeospatialCrsWkt2Reader::readFromJson ( const std::span< const std::byte > & data) const
