CesiumGltfReader::ExtensionExtGeospatialCrsWkidReader Class Reference
Reads ExtensionExtGeospatialCrsWkid instances from JSON. More...
#include <CesiumGltfReader/ExtensionExtGeospatialCrsWkidReader.h>
 ExtensionExtGeospatialCrsWkidReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtGeospatialCrsWkid > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionExtGeospatialCrsWkid from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtGeospatialCrsWkid > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionExtGeospatialCrsWkid from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtGeospatialCrsWkid > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionExtGeospatialCrsWkid from a rapidJson::Value.
Definition at line 25 of file ExtensionExtGeospatialCrsWkidReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtGeospatialCrsWkid > > CesiumGltfReader::ExtensionExtGeospatialCrsWkidReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtGeospatialCrsWkid > CesiumGltfReader::ExtensionExtGeospatialCrsWkidReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtGeospatialCrsWkid > CesiumGltfReader::ExtensionExtGeospatialCrsWkidReader::readFromJson ( const std::span< const std::byte > & data) const
