CesiumGltfReader::ExtensionExtGeospatialCrsReader Class Reference
Reads ExtensionExtGeospatialCrs instances from JSON. More...
#include <CesiumGltfReader/ExtensionExtGeospatialCrsReader.h>
 ExtensionExtGeospatialCrsReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtGeospatialCrs > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionExtGeospatialCrs from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtGeospatialCrs > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionExtGeospatialCrs from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtGeospatialCrs > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionExtGeospatialCrs from a rapidJson::Value.
Definition at line 25 of file ExtensionExtGeospatialCrsReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionExtGeospatialCrs > > CesiumGltfReader::ExtensionExtGeospatialCrsReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtGeospatialCrs > CesiumGltfReader::ExtensionExtGeospatialCrsReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionExtGeospatialCrs > CesiumGltfReader::ExtensionExtGeospatialCrsReader::readFromJson ( const std::span< const std::byte > & data) const
