CesiumGltfReader::ExtensionCesiumPrimitiveOutlineReader Class Reference
Reads ExtensionCesiumPrimitiveOutline instances from JSON. More...
#include <CesiumGltfReader/ExtensionCesiumPrimitiveOutlineReader.h>
 ExtensionCesiumPrimitiveOutlineReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionCesiumPrimitiveOutline > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionCesiumPrimitiveOutline from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionCesiumPrimitiveOutline > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionCesiumPrimitiveOutline from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionCesiumPrimitiveOutline > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionCesiumPrimitiveOutline from a rapidJson::Value.
Definition at line 25 of file ExtensionCesiumPrimitiveOutlineReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionCesiumPrimitiveOutline > > CesiumGltfReader::ExtensionCesiumPrimitiveOutlineReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionCesiumPrimitiveOutline > CesiumGltfReader::ExtensionCesiumPrimitiveOutlineReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionCesiumPrimitiveOutline > CesiumGltfReader::ExtensionCesiumPrimitiveOutlineReader::readFromJson ( const std::span< const std::byte > & data) const
