Reads ExtensionBufferViewExtMeshoptCompression instances from JSON. More...
#include <CesiumGltfReader/ExtensionBufferViewExtMeshoptCompressionReader.h>
| ExtensionBufferViewExtMeshoptCompressionReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionBufferViewExtMeshoptCompression > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of ExtensionBufferViewExtMeshoptCompression from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionBufferViewExtMeshoptCompression > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of ExtensionBufferViewExtMeshoptCompression from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionBufferViewExtMeshoptCompression > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of ExtensionBufferViewExtMeshoptCompression from a rapidJson::Value. | |
Definition at line 25 of file ExtensionBufferViewExtMeshoptCompressionReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionBufferViewExtMeshoptCompression > > CesiumGltfReader::ExtensionBufferViewExtMeshoptCompressionReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionBufferViewExtMeshoptCompression > CesiumGltfReader::ExtensionBufferViewExtMeshoptCompressionReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionBufferViewExtMeshoptCompression > CesiumGltfReader::ExtensionBufferViewExtMeshoptCompressionReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
