CesiumGltfReader::ExtensionBentleyMaterialsPointStyleReader Class Reference
Reads ExtensionBentleyMaterialsPointStyle instances from JSON. More...
#include <CesiumGltfReader/ExtensionBentleyMaterialsPointStyleReader.h>
 ExtensionBentleyMaterialsPointStyleReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionBentleyMaterialsPointStyle > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionBentleyMaterialsPointStyle from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionBentleyMaterialsPointStyle > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionBentleyMaterialsPointStyle from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionBentleyMaterialsPointStyle > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionBentleyMaterialsPointStyle from a rapidJson::Value.
Definition at line 25 of file ExtensionBentleyMaterialsPointStyleReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::ExtensionBentleyMaterialsPointStyle > > CesiumGltfReader::ExtensionBentleyMaterialsPointStyleReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionBentleyMaterialsPointStyle > CesiumGltfReader::ExtensionBentleyMaterialsPointStyleReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::ExtensionBentleyMaterialsPointStyle > CesiumGltfReader::ExtensionBentleyMaterialsPointStyleReader::readFromJson ( const std::span< const std::byte > & data) const
