CesiumGltfReader::Extension3dTilesTilesetVectorsReader Class Reference
Reads Extension3dTilesTilesetVectors instances from JSON. More...
#include <CesiumGltfReader/Extension3dTilesTilesetVectorsReader.h>
 Extension3dTilesTilesetVectorsReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesTilesetVectors > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Extension3dTilesTilesetVectors from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesTilesetVectors > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Extension3dTilesTilesetVectors from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Extension3dTilesTilesetVectors > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Extension3dTilesTilesetVectors from a rapidJson::Value.
Definition at line 25 of file Extension3dTilesTilesetVectorsReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Extension3dTilesTilesetVectors > > CesiumGltfReader::Extension3dTilesTilesetVectorsReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesTilesetVectors > CesiumGltfReader::Extension3dTilesTilesetVectorsReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesTilesetVectors > CesiumGltfReader::Extension3dTilesTilesetVectorsReader::readFromJson ( const std::span< const std::byte > & data) const
