CesiumGltfReader::Extension3dTilesShapeEllipsoidRegionReader Class Reference
Reads Extension3dTilesShapeEllipsoidRegion instances from JSON. More...
#include <CesiumGltfReader/Extension3dTilesShapeEllipsoidRegionReader.h>
 Extension3dTilesShapeEllipsoidRegionReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesShapeEllipsoidRegion > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Extension3dTilesShapeEllipsoidRegion from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesShapeEllipsoidRegion > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Extension3dTilesShapeEllipsoidRegion from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Extension3dTilesShapeEllipsoidRegion > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Extension3dTilesShapeEllipsoidRegion from a rapidJson::Value.
Definition at line 25 of file Extension3dTilesShapeEllipsoidRegionReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Extension3dTilesShapeEllipsoidRegion > > CesiumGltfReader::Extension3dTilesShapeEllipsoidRegionReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesShapeEllipsoidRegion > CesiumGltfReader::Extension3dTilesShapeEllipsoidRegionReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesShapeEllipsoidRegion > CesiumGltfReader::Extension3dTilesShapeEllipsoidRegionReader::readFromJson ( const std::span< const std::byte > & data) const
