Reads Extension3dTilesShapeCylinderRegion instances from JSON. More...
#include <CesiumGltfReader/Extension3dTilesShapeCylinderRegionReader.h>
| Extension3dTilesShapeCylinderRegionReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesShapeCylinderRegion > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of Extension3dTilesShapeCylinderRegion from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesShapeCylinderRegion > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of Extension3dTilesShapeCylinderRegion from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Extension3dTilesShapeCylinderRegion > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of Extension3dTilesShapeCylinderRegion from a rapidJson::Value. | |
Definition at line 25 of file Extension3dTilesShapeCylinderRegionReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Extension3dTilesShapeCylinderRegion > > CesiumGltfReader::Extension3dTilesShapeCylinderRegionReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesShapeCylinderRegion > CesiumGltfReader::Extension3dTilesShapeCylinderRegionReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::Extension3dTilesShapeCylinderRegion > CesiumGltfReader::Extension3dTilesShapeCylinderRegionReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
