CesiumGltfReader::CapsuleReader Class Reference
Reads Capsule instances from JSON. More...
#include <CesiumGltfReader/CapsuleReader.h>
 CapsuleReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Capsule > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Capsule from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Capsule > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Capsule from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Capsule > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Capsule from a rapidJson::Value.
Definition at line 24 of file CapsuleReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Capsule > > CesiumGltfReader::CapsuleReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Capsule > CesiumGltfReader::CapsuleReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Capsule > CesiumGltfReader::CapsuleReader::readFromJson ( const std::span< const std::byte > & data) const
