CesiumGltfReader::BufferViewReader Class Reference
Reads BufferView instances from JSON. More...
#include <CesiumGltfReader/BufferViewReader.h>
 BufferViewReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::BufferView > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of BufferView from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::BufferView > readFromJson (const rapidjson::Value &value) const
 Reads an instance of BufferView from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::BufferView > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of BufferView from a rapidJson::Value.
Definition at line 24 of file BufferViewReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::BufferView > > CesiumGltfReader::BufferViewReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::BufferView > CesiumGltfReader::BufferViewReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::BufferView > CesiumGltfReader::BufferViewReader::readFromJson ( const std::span< const std::byte > & data) const
