CesiumGltfReader::AvailabilityReader Class Reference
Reads Availability instances from JSON. More...
#include <CesiumGltfReader/AvailabilityReader.h>
 AvailabilityReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Availability > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Availability from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Availability > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Availability from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Availability > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Availability from a rapidJson::Value.
Definition at line 25 of file AvailabilityReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Availability > > CesiumGltfReader::AvailabilityReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Availability > CesiumGltfReader::AvailabilityReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Availability > CesiumGltfReader::AvailabilityReader::readFromJson ( const std::span< const std::byte > & data) const
