CesiumGltfReader::AssetReader Class Reference
Reads Asset instances from JSON. More...
#include <CesiumGltfReader/AssetReader.h>
 AssetReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Asset > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Asset from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Asset > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Asset from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Asset > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Asset from a rapidJson::Value.
Definition at line 24 of file AssetReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Asset > > CesiumGltfReader::AssetReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Asset > CesiumGltfReader::AssetReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Asset > CesiumGltfReader::AssetReader::readFromJson ( const std::span< const std::byte > & data) const
