CesiumGltfReader::AnimationReader Class Reference
Reads Animation instances from JSON. More...
#include <CesiumGltfReader/AnimationReader.h>
 AnimationReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Animation > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Animation from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Animation > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Animation from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Animation > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Animation from a rapidJson::Value.
Definition at line 24 of file AnimationReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Animation > > CesiumGltfReader::AnimationReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Animation > CesiumGltfReader::AnimationReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Animation > CesiumGltfReader::AnimationReader::readFromJson ( const std::span< const std::byte > & data) const
