CesiumGltfReader::AnimationChannelTargetReader Class Reference
Reads AnimationChannelTarget instances from JSON. More...
#include <CesiumGltfReader/AnimationChannelTargetReader.h>
 AnimationChannelTargetReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::AnimationChannelTarget > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of AnimationChannelTarget from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::AnimationChannelTarget > readFromJson (const rapidjson::Value &value) const
 Reads an instance of AnimationChannelTarget from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::AnimationChannelTarget > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of AnimationChannelTarget from a rapidJson::Value.
Definition at line 25 of file AnimationChannelTargetReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::AnimationChannelTarget > > CesiumGltfReader::AnimationChannelTargetReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::AnimationChannelTarget > CesiumGltfReader::AnimationChannelTargetReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::AnimationChannelTarget > CesiumGltfReader::AnimationChannelTargetReader::readFromJson ( const std::span< const std::byte > & data) const
