CesiumGltfReader::AnimationChannelReader Class Reference
Reads AnimationChannel instances from JSON. More...
#include <CesiumGltfReader/AnimationChannelReader.h>
 AnimationChannelReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::AnimationChannel > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of AnimationChannel from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::AnimationChannel > readFromJson (const rapidjson::Value &value) const
 Reads an instance of AnimationChannel from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::AnimationChannel > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of AnimationChannel from a rapidJson::Value.
Definition at line 25 of file AnimationChannelReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::AnimationChannel > > CesiumGltfReader::AnimationChannelReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::AnimationChannel > CesiumGltfReader::AnimationChannelReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::AnimationChannel > CesiumGltfReader::AnimationChannelReader::readFromJson ( const std::span< const std::byte > & data) const
