CesiumGltfReader::AccessorSparseValuesReader Class Reference
Reads AccessorSparseValues instances from JSON. More...
#include <CesiumGltfReader/AccessorSparseValuesReader.h>
 AccessorSparseValuesReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::AccessorSparseValues > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of AccessorSparseValues from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::AccessorSparseValues > readFromJson (const rapidjson::Value &value) const
 Reads an instance of AccessorSparseValues from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::AccessorSparseValues > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of AccessorSparseValues from a rapidJson::Value.
Definition at line 25 of file AccessorSparseValuesReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::AccessorSparseValues > > CesiumGltfReader::AccessorSparseValuesReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::AccessorSparseValues > CesiumGltfReader::AccessorSparseValuesReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::AccessorSparseValues > CesiumGltfReader::AccessorSparseValuesReader::readFromJson ( const std::span< const std::byte > & data) const
