CesiumGltfReader::AccessorSparseReader Class Reference
Reads AccessorSparse instances from JSON. More...
#include <CesiumGltfReader/AccessorSparseReader.h>
 AccessorSparseReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::AccessorSparse > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of AccessorSparse from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::AccessorSparse > readFromJson (const rapidjson::Value &value) const
 Reads an instance of AccessorSparse from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::AccessorSparse > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of AccessorSparse from a rapidJson::Value.
Definition at line 25 of file AccessorSparseReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::AccessorSparse > > CesiumGltfReader::AccessorSparseReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::AccessorSparse > CesiumGltfReader::AccessorSparseReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::AccessorSparse > CesiumGltfReader::AccessorSparseReader::readFromJson ( const std::span< const std::byte > & data) const
