CesiumGltfReader::AccessorReader Class Reference
Reads Accessor instances from JSON. More...
#include <CesiumGltfReader/AccessorReader.h>
 AccessorReader ()
CesiumJsonReader::ReadJsonResult< CesiumGltf::Accessor > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Accessor from a byte buffer.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Accessor > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Accessor from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Accessor > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Accessor from a rapidJson::Value.
Definition at line 24 of file AccessorReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Accessor > > CesiumGltfReader::AccessorReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Accessor > CesiumGltfReader::AccessorReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< CesiumGltf::Accessor > CesiumGltfReader::AccessorReader::readFromJson ( const std::span< const std::byte > & data) const
