CesiumAsync::SqliteCache Class Reference
Cache storage using SQLITE to store completed response. More...
#include <CesiumAsync/SqliteCache.h>
Inheritance diagram for CesiumAsync::SqliteCache:
CesiumAsync::ICacheDatabase
 SqliteCache (const std::shared_ptr< spdlog::logger > &pLogger, const std::string &databaseName, uint64_t maxItems=4096)
 Constructs a new instance with a given databaseName pointing to a database.
virtual std::optional< CacheItem > getEntry (const std::string &key) const override
 Gets a cache entry from the database.
virtual bool storeEntry (const std::string &key, std::time_t expiryTime, const std::string &url, const std::string &requestMethod, const HttpHeaders &requestHeaders, uint16_t statusCode, const HttpHeaders &responseHeaders, const std::span< const std::byte > &responseData) override
 Store a cache entry in the database.
virtual bool prune () override
 Remove cache entries from the database to satisfy the database invariant condition (.e.g exired response or LRU).
virtual bool clearAll () override
 Removes all cache entries from the database.
Definition at line 17 of file SqliteCache.h.
◆ SqliteCache()
CesiumAsync::SqliteCache::SqliteCache ( const std::shared_ptr< spdlog::logger > & pLogger,
const std::string & databaseName,
uint64_t maxItems = 4096 )
The instance will connect to the existing database or create a new one if it doesn't exist
pLoggerThe logger that receives error messages.
databaseNamethe database path.
maxItemsthe maximum number of items should be kept in the database after prunning.
◆ clearAll()
virtual bool CesiumAsync::SqliteCache::clearAll ( )
overridevirtual
true if the database was successfully cleared, or false if it could not be pruned due to an errror.
Implements CesiumAsync::ICacheDatabase.
◆ getEntry()
virtual std::optional< CacheItem > CesiumAsync::SqliteCache::getEntry ( const std::string & key) const
overridevirtual
If an error prevents checking the database for the key, this function, depending on the implementation, may log the error. However, it should return std::nullopt. It should not throw an exception.
keyThe unique key associated with the cache entry.
The result of the cache lookup, or std::nullopt if the key does not exist in the cache or an error occurred.
◆ prune()
virtual bool CesiumAsync::SqliteCache::prune ( )
overridevirtual
true if the database was successfully pruned, or false if it could not be pruned due to an errror.
◆ storeEntry()
virtual bool CesiumAsync::SqliteCache::storeEntry ( const std::string & key,
const std::string & url,
const std::string & requestMethod,
const HttpHeaders & requestHeaders,
const HttpHeaders & responseHeaders,
const std::span< const std::byte > & responseData )
overridevirtual
keythe unique key associated with the response
expiryTimethe time point that this response should be expired. An expired response will be removed when prunning the database.
urlThe URL being cached.
requestMethodThe HTTP method being cached.
requestHeadersThe HTTP request headers being cached.
statusCodeThe HTTP response status code being cached.
responseHeadersThe HTTP response headers being cached.
responseDataThe HTTP response being cached.
true if the entry was successfully stored, or false if it could not be stored due to an error.
