cesium-native 0.65.0
Cesium3DTilesReader::StatisticsReader Class Reference
Reads Statistics instances from JSON. More...
#include <Cesium3DTilesReader/StatisticsReader.h>
 StatisticsReader ()
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Statistics > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Statistics from a byte buffer.
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Statistics > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Statistics from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::Statistics > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Statistics from a rapidJson::Value.
Definition at line 24 of file StatisticsReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::Statistics > > Cesium3DTilesReader::StatisticsReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Statistics > Cesium3DTilesReader::StatisticsReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Statistics > Cesium3DTilesReader::StatisticsReader::readFromJson ( const std::span< const std::byte > & data) const
