cesium-native 0.65.0
Cesium3DTilesReader::ImplicitTilingReader Class Reference
Reads ImplicitTiling instances from JSON. More...
#include <Cesium3DTilesReader/ImplicitTilingReader.h>
 ImplicitTilingReader ()
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ImplicitTiling > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ImplicitTiling from a byte buffer.
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ImplicitTiling > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ImplicitTiling from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::ImplicitTiling > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ImplicitTiling from a rapidJson::Value.
Definition at line 25 of file ImplicitTilingReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::ImplicitTiling > > Cesium3DTilesReader::ImplicitTilingReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ImplicitTiling > Cesium3DTilesReader::ImplicitTilingReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ImplicitTiling > Cesium3DTilesReader::ImplicitTilingReader::readFromJson ( const std::span< const std::byte > & data) const
