cesium-native 0.65.0
Cesium3DTilesReader::ExtensionSchemaMaxarContentGeoJsonPropertiesValueReader Class Reference
Reads ExtensionSchemaMaxarContentGeoJsonPropertiesValue instances from JSON. More...
#include <Cesium3DTilesReader/ExtensionSchemaMaxarContentGeoJsonPropertiesValueReader.h>
 ExtensionSchemaMaxarContentGeoJsonPropertiesValueReader ()
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionSchemaMaxarContentGeoJsonPropertiesValue from a byte buffer.
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionSchemaMaxarContentGeoJsonPropertiesValue from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionSchemaMaxarContentGeoJsonPropertiesValue from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue > > Cesium3DTilesReader::ExtensionSchemaMaxarContentGeoJsonPropertiesValueReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue > Cesium3DTilesReader::ExtensionSchemaMaxarContentGeoJsonPropertiesValueReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue > Cesium3DTilesReader::ExtensionSchemaMaxarContentGeoJsonPropertiesValueReader::readFromJson ( const std::span< const std::byte > & data) const
