cesium-native 0.65.0
Cesium3DTilesReader::ExtensionMetadataEntityMaxarContentGeoJsonReader Class Reference
Reads ExtensionMetadataEntityMaxarContentGeoJson instances from JSON. More...
#include <Cesium3DTilesReader/ExtensionMetadataEntityMaxarContentGeoJsonReader.h>
 ExtensionMetadataEntityMaxarContentGeoJsonReader ()
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ExtensionMetadataEntityMaxarContentGeoJson > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ExtensionMetadataEntityMaxarContentGeoJson from a byte buffer.
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ExtensionMetadataEntityMaxarContentGeoJson > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ExtensionMetadataEntityMaxarContentGeoJson from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::ExtensionMetadataEntityMaxarContentGeoJson > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ExtensionMetadataEntityMaxarContentGeoJson from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::ExtensionMetadataEntityMaxarContentGeoJson > > Cesium3DTilesReader::ExtensionMetadataEntityMaxarContentGeoJsonReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ExtensionMetadataEntityMaxarContentGeoJson > Cesium3DTilesReader::ExtensionMetadataEntityMaxarContentGeoJsonReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ExtensionMetadataEntityMaxarContentGeoJson > Cesium3DTilesReader::ExtensionMetadataEntityMaxarContentGeoJsonReader::readFromJson ( const std::span< const std::byte > & data) const
