cesium-native 0.65.0
Cesium3DTilesReader::Extension3dTilesContentConditionalReader Class Reference
Reads Extension3dTilesContentConditional instances from JSON. More...
#include <Cesium3DTilesReader/Extension3dTilesContentConditionalReader.h>
 Extension3dTilesContentConditionalReader ()
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Extension3dTilesContentConditional > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Extension3dTilesContentConditional from a byte buffer.
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Extension3dTilesContentConditional > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Extension3dTilesContentConditional from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::Extension3dTilesContentConditional > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Extension3dTilesContentConditional from a rapidJson::Value.
Definition at line 25 of file Extension3dTilesContentConditionalReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::Extension3dTilesContentConditional > > Cesium3DTilesReader::Extension3dTilesContentConditionalReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Extension3dTilesContentConditional > Cesium3DTilesReader::Extension3dTilesContentConditionalReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Extension3dTilesContentConditional > Cesium3DTilesReader::Extension3dTilesContentConditionalReader::readFromJson ( const std::span< const std::byte > & data) const
