cesium-native 0.65.0
Cesium3DTilesReader::Extension3dTilesContentConditionalDimensionsValueReader Class Reference
Reads Extension3dTilesContentConditionalDimensionsValue instances from JSON. More...
#include <Cesium3DTilesReader/Extension3dTilesContentConditionalDimensionsValueReader.h>
 Extension3dTilesContentConditionalDimensionsValueReader ()
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Extension3dTilesContentConditionalDimensionsValue > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Extension3dTilesContentConditionalDimensionsValue from a byte buffer.
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Extension3dTilesContentConditionalDimensionsValue > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Extension3dTilesContentConditionalDimensionsValue from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::Extension3dTilesContentConditionalDimensionsValue > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Extension3dTilesContentConditionalDimensionsValue from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::Extension3dTilesContentConditionalDimensionsValue > > Cesium3DTilesReader::Extension3dTilesContentConditionalDimensionsValueReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Extension3dTilesContentConditionalDimensionsValue > Cesium3DTilesReader::Extension3dTilesContentConditionalDimensionsValueReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Extension3dTilesContentConditionalDimensionsValue > Cesium3DTilesReader::Extension3dTilesContentConditionalDimensionsValueReader::readFromJson ( const std::span< const std::byte > & data) const
