Cesium3DTilesReader::ClassReader Class Reference
Reads Class instances from JSON. More...
#include <Cesium3DTilesReader/ClassReader.h>
 ClassReader ()
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Class > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of Class from a byte buffer.
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Class > readFromJson (const rapidjson::Value &value) const
 Reads an instance of Class from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::Class > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of Class from a rapidJson::Value.
Definition at line 24 of file ClassReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::Class > > Cesium3DTilesReader::ClassReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Class > Cesium3DTilesReader::ClassReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::Class > Cesium3DTilesReader::ClassReader::readFromJson ( const std::span< const std::byte > & data) const
