cesium-native 0.65.0
Cesium3DTilesReader::ClassPropertyReader Class Reference
Reads ClassProperty instances from JSON. More...
#include <Cesium3DTilesReader/ClassPropertyReader.h>
 ClassPropertyReader ()
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ClassProperty > readFromJson (const std::span< const std::byte > &data) const
 Reads an instance of ClassProperty from a byte buffer.
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ClassProperty > readFromJson (const rapidjson::Value &value) const
 Reads an instance of ClassProperty from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::ClassProperty > > readArrayFromJson (const rapidjson::Value &value) const
 Reads an array of instances of ClassProperty from a rapidJson::Value.
Definition at line 25 of file ClassPropertyReader.h.
CesiumJsonReader::ReadJsonResult< std::vector< Cesium3DTiles::ClassProperty > > Cesium3DTilesReader::ClassPropertyReader::readArrayFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ClassProperty > Cesium3DTilesReader::ClassPropertyReader::readFromJson ( const rapidjson::Value & value) const
CesiumJsonReader::ReadJsonResult< Cesium3DTiles::ClassProperty > Cesium3DTilesReader::ClassPropertyReader::readFromJson ( const std::span< const std::byte > & data) const
