3#include <CesiumJsonWriter/ExtensionWriterContext.h>
4#include <CesiumTilesetJsonWriter/Library.h>
SchemaWriterResult writeSchema(const CesiumTilesetJson::Schema &schema, const SchemaWriterOptions &options=SchemaWriterOptions()) const
Serializes the provided schema object into a byte vector using the provided flags to convert.
SchemaWriter()
CesiumJsonWriter::ExtensionWriterContext & getExtensions()
Gets the context used to control how schema extensions are written.
const CesiumJsonWriter::ExtensionWriterContext & getExtensions() const
Classes for writing a tileset.json from 3D Tiles 1.1.
Options for how to write a schema.
bool prettyPrint
If the schema JSON should be pretty printed.
The result of writing a schema with SchemaWriter::writeSchema.
std::vector< std::byte > schemaBytes
The final generated std::vector<std::byte> of the schema JSON.
