PropertyTableProperty.h
9#include <cstdint>
10#include <optional>
11#include <string>
12
13namespace Cesium3DTiles {
19struct CESIUM3DTILES_API PropertyTableProperty final
24 static constexpr const char* TypeName = "PropertyTableProperty";
25
31 inline static const std::string UINT8 = "UINT8";
32
34 inline static const std::string UINT16 = "UINT16";
35
37 inline static const std::string UINT32 = "UINT32";
38
40 inline static const std::string UINT64 = "UINT64";
41 };
42
48 inline static const std::string UINT8 = "UINT8";
49
51 inline static const std::string UINT16 = "UINT16";
52
54 inline static const std::string UINT32 = "UINT32";
55
57 inline static const std::string UINT64 = "UINT64";
58 };
59
75 int64_t values = int64_t();
76
89 std::optional<int64_t> arrayOffsets;
90
101 std::optional<int64_t> stringOffsets;
102
110
118
124 std::optional<CesiumUtility::JsonValue> offset;
125
131 std::optional<CesiumUtility::JsonValue> scale;
132
139 std::optional<CesiumUtility::JsonValue> max;
140
147 std::optional<CesiumUtility::JsonValue> min;
148
155 int64_t getSizeBytes() const {
156 int64_t accum = 0;
157 accum += int64_t(sizeof(PropertyTableProperty));
159 int64_t(sizeof(CesiumUtility::ExtensibleObject));
160
161 return accum;
162 }
163};
164} // namespace Cesium3DTiles
Classes for using 3D Tiles.
Definition Buffer.h:7
Known values for The type of values in arrayOffsets.
Known values for The type of values in stringOffsets.
An array of binary property values. This represents one column of a property table,...
A scale to apply to property values. Only applicable when the component type is FLOAT32 or FLOAT64,...
std::optional< int64_t > stringOffsets
The index of the buffer view containing offsets for strings. The number of offsets is equal to the nu...
Minimum value present in the property values. Only applicable to SCALAR, VECN, and MATN types....
Maximum value present in the property values. Only applicable to SCALAR, VECN, and MATN types....
An offset to apply to property values. Only applicable when the component type is FLOAT32 or FLOAT64,...
std::string arrayOffsetType
std::optional< int64_t > arrayOffsets
The index of the buffer view containing offsets for variable-length arrays. The number of offsets is ...
int64_t values
The index of the buffer view containing property values. The data type of property values is determin...
std::string stringOffsetType
