Cesium for Unreal 2.31.0
Description of a feature texture property that should be uploaded to the GPU. More...
#include <CesiumEncodedMetadataComponent.h>
| FString | Name |
| The name of this property as it will be referenced in the material. | |
| ECesiumPropertyType_DEPRECATED | Type |
| The property type. | |
| bool | Normalized = false |
| If ComponentType==Uint8, this indicates whether to normalize into a [0-1] range before accessing on the GPU. | |
| FString | Swizzle |
| This string describes the channel order of the incoming feature texture property (e.g., "rgb", "bgra", etc.). | |
Definition at line 161 of file CesiumEncodedMetadataComponent.h.
| FString FFeatureTexturePropertyDescription::Name |
Definition at line 169 of file CesiumEncodedMetadataComponent.h.
| bool FFeatureTexturePropertyDescription::Normalized = false |
Definition at line 189 of file CesiumEncodedMetadataComponent.h.
| FString FFeatureTexturePropertyDescription::Swizzle |
This helps us fix the channel order when accessing on the GPU.
Definition at line 197 of file CesiumEncodedMetadataComponent.h.
| ECesiumPropertyType_DEPRECATED FFeatureTexturePropertyDescription::Type |
The property type.
Definition at line 181 of file CesiumEncodedMetadataComponent.h.
