Cesium for Unreal 2.14.0
Reference Frames
This is an inventory of the most important reference frames used in Cesium for Unreal.
Ellipsoid-centered
This is the "native" reference frame of Cesium.
Handedness Right
Units Meters
Origin Center of the ellipsoid (Earth)
Orientation
  • +X passes through the intersection of the equator and prime meridian (0 degrees latitude, 0 degrees longitude)
  • +Y passes through the intersection of the equator and +90 degrees longitude (0 degrees latitude, 90 degrees longitude)
  • +Z is up through the North Pole
Georeferenced
A reference frame defined by the ACesiumGeoreference actor.
Handedness Right
Units Meters
Origin The origin defined by the ACesiumGeoreference::OriginPlacement and possibly OriginLongitude, OriginLatitude, and OriginHeight properties.
Orientation
  • If ACesiumGeoreference::AlignTilesetUpWithZ is true:
    • +X points East at the origin
    • +Y points North at the origin
    • +Z is in the direction of the ellipsoid surface normal at the origin (up)
  • If ACesiumGeoreference::AlignTilesetUpWithZ is false:
    • Same as Ellipsoid-centered above.
Cesium Tileset
The reference frame of a Cesium 3D Tiles tileset, as defined by the tileset.json. Usually, tilesets are georeferenced and this reference frame is identical to the Ellipsoid-centered frame described above, but this is not strictly required by 3D Tiles. A non-georeferenced model of a building, for example, may have an origin at the center of the building and axes aligned with the principal sides of the building.
Handedness Right
Units Meters
Origin Specified by tileset.json, often the center of the Earth.
Orientation Specified by tileset.json, often ECEF.
Unreal Tileset
The same as the Cesium Tileset, but expressed in Unreal Engine terms: the coordinates are in centimeters (multiplied by 100.0) and left-handed (have an inverted Y component) relative to Cesium Tileset coordinates.
Please note that the transformation from Unreal Tileset coordinates to Unreal Absolute/Relative World (below) is affected by the ACesium3DTileset Actor's Location and Orientation properties. However, these should almost always be set to identity.
Handedness Left
Units Centimeters
Unreal Absolute World
Vectors and matrices in Unreal Engine are expressed using single-precision floating-point numbers. In order to maintain precision, these coordinate values must remain relatively small. To support this, the Unreal floating world origin can be moved by setting the OriginLocation property of UWorld. Coordinates that are said to be in the "Unreal Absolute World" reference frame are expressed relative to the absolute origin (0,0,0) and are not affected by the value of the OriginLocation property.
Handedness Left
Units Centimeters
Origin No fixed meaning.
Orientation No fixed meaning.
Unreal Relative World
This reference frame has the same orientation as "Unreal Absolute World", but is offset from it by the UWorld's OriginLocation. Coordinates are expressed relative to the floating origin.
Handedness Left
Units Centimeters
