UCesiumWgs84Ellipsoid Class Reference
#include <CesiumWgs84Ellipsoid.h>
Inheritance diagram for UCesiumWgs84Ellipsoid:
static FVector GetRadii ()
 Gets the radii of the WGS84 ellipsoid in its x-, y-, and z-directions in meters.
static double GetMaximumRadius ()
 Gets the maximum radius of the WGS84 ellipsoid in any dimension, in meters.
static double GetMinimumRadius ()
 Gets the minimum radius of the WGS854 ellipsoid in any dimension, in meters.
static FVector ScaleToGeodeticSurface (const FVector &EarthCenteredEarthFixedPosition)
 Scale the given Earth-Centered, Earth-Fixed position along the geodetic surface normal so that it is on the surface of the ellipsoid.
static FVector GeodeticSurfaceNormal (const FVector &EarthCenteredEarthFixedPosition)
 Computes the normal of the plane tangent to the surface of the ellipsoid at the provided Earth-Centered, Earth-Fixed position.
static FVector LongitudeLatitudeHeightToEarthCenteredEarthFixed (const FVector &LongitudeLatitudeHeight)
 Convert longitude in degrees (X), latitude in degrees (Y), and height above the WGS84 ellipsoid in meters (Z) to Earth-Centered, Earth-Fixed (ECEF) coordinates.
static FVector EarthCenteredEarthFixedToLongitudeLatitudeHeight (const FVector &EarthCenteredEarthFixedPosition)
 Convert Earth-Centered, Earth-Fixed (ECEF) coordinates to longitude in degrees (X), latitude in degrees (Y), and height above the WGS84 ellipsoid in meters (Z).
static FMatrix EastNorthUpToEarthCenteredEarthFixed (const FVector &EarthCenteredEarthFixedPosition)
 Computes the transformation matrix from the local East-North-Up (ENU) frame to Earth-Centered, Earth-Fixed (ECEF) at the specified ECEF location.
Definition at line 11 of file CesiumWgs84Ellipsoid.h.
◆ EarthCenteredEarthFixedToLongitudeLatitudeHeight()
static FVector UCesiumWgs84Ellipsoid::EarthCenteredEarthFixedToLongitudeLatitudeHeight ( const FVector & EarthCenteredEarthFixedPosition)
static
If the position is near the center of the Earth, the result will have the value (0,0,0) because the longitude, latitude, and height are undefined.
◆ EastNorthUpToEarthCenteredEarthFixed()
static FMatrix UCesiumWgs84Ellipsoid::EastNorthUpToEarthCenteredEarthFixed ( const FVector & EarthCenteredEarthFixedPosition)
static
◆ GeodeticSurfaceNormal()
static FVector UCesiumWgs84Ellipsoid::GeodeticSurfaceNormal ( const FVector & EarthCenteredEarthFixedPosition)
static
◆ GetMaximumRadius()
static double UCesiumWgs84Ellipsoid::GetMaximumRadius ( )
static
◆ GetMinimumRadius()
static double UCesiumWgs84Ellipsoid::GetMinimumRadius ( )
static
◆ GetRadii()
static FVector UCesiumWgs84Ellipsoid::GetRadii ( )
static
◆ LongitudeLatitudeHeightToEarthCenteredEarthFixed()
static FVector UCesiumWgs84Ellipsoid::LongitudeLatitudeHeightToEarthCenteredEarthFixed ( const FVector & LongitudeLatitudeHeight)
static
◆ ScaleToGeodeticSurface()
static FVector UCesiumWgs84Ellipsoid::ScaleToGeodeticSurface ( const FVector & EarthCenteredEarthFixedPosition)
static
If the position is near the center of the ellipsoid, the result will have the value (0,0,0) because the surface position is undefined.
