UCesiumTileExcluder Class Reference
#include <CesiumTileExcluder.h>
Inheritance diagram for UCesiumTileExcluder:
 UCesiumTileExcluder (const FObjectInitializer &ObjectInitializer)
void AddToTileset ()
 Adds this tile excluder to its owning Cesium 3D Tileset Actor.
void RemoveFromTileset ()
 Removes this tile excluder from its owning Cesium 3D Tileset Actor.
void Refresh ()
 Refreshes this tile excluderby removing from its owning Cesium 3D Tileset Actor and re-adding it.
bool ShouldExclude (const UCesiumTile *TileObject)
 Determines whether a tile should be excluded.
Definition at line 24 of file CesiumTileExcluder.h.
◆ UCesiumTileExcluder()
UCesiumTileExcluder::UCesiumTileExcluder ( const FObjectInitializer & ObjectInitializer)
◆ Activate()
virtual void UCesiumTileExcluder::Activate ( bool bReset)
overridevirtual
◆ AddToTileset()
void UCesiumTileExcluder::AddToTileset ( )
If the excluder is already added or if this component's Owner is not a Cesium 3D Tileset, this method does nothing.
◆ Deactivate()
virtual void UCesiumTileExcluder::Deactivate ( )
overridevirtual
◆ OnComponentDestroyed()
virtual void UCesiumTileExcluder::OnComponentDestroyed ( bool bDestroyingHierarchy)
overridevirtual
◆ Refresh()
void UCesiumTileExcluder::Refresh ( )
If this component's Owner is not a Cesium 3D Tileset Actor, this method does nothing.
◆ RemoveFromTileset()
void UCesiumTileExcluder::RemoveFromTileset ( )
If the excluder is not yet added or if this component's Owner is not a Cesium 3D Tileset, this method does nothing.
◆ ShouldExclude()
bool UCesiumTileExcluder::ShouldExclude ( const UCesiumTile * TileObject)
This function is called to determine whether a tile should be excluded from the tileset. You can override this function in a derived class or blueprint to implement custom exclusion logic.
