UCesiumSampleHeightMostDetailedAsyncAction Class Reference
#include <CesiumSampleHeightMostDetailedAsyncAction.h>
Inheritance diagram for UCesiumSampleHeightMostDetailedAsyncAction:
virtual void Activate () override
static UCesiumSampleHeightMostDetailedAsyncAction * SampleHeightMostDetailed (ACesium3DTileset *Tileset, const TArray< FVector > &LongitudeLatitudeHeightArray)
 Asynchronously samples the height of the tileset at a list of cartographic positions, each expressed as a Longitude (X) and Latitude (Y) in degrees.
FCesiumSampleHeightMostDetailedComplete OnHeightsSampled
 Called when height has been sampled at all of the given positions.
Definition at line 29 of file CesiumSampleHeightMostDetailedAsyncAction.h.
◆ Activate()
virtual void UCesiumSampleHeightMostDetailedAsyncAction::Activate ( )
overridevirtual
◆ SampleHeightMostDetailed()
static UCesiumSampleHeightMostDetailedAsyncAction * UCesiumSampleHeightMostDetailedAsyncAction::SampleHeightMostDetailed ( ACesium3DTileset * Tileset,
const TArray< FVector > & LongitudeLatitudeHeightArray )
static
The Height (Z) provided on input is ignored unless the sampling fails at that position, in which case it is passed through to the output.
TilesetThe tileset from which to query heights.
LongitudeLatitudeHeightArrayThe array of cartographic positions at which to query heights, with Longitude in the X component and Latitude in the Y component.
◆ OnHeightsSampled
FCesiumSampleHeightMostDetailedComplete UCesiumSampleHeightMostDetailedAsyncAction::OnHeightsSampled
The Result property contains an element for each input position and in the same order. The Warnings property provides information about problems that were encountered while sampling heights.
Definition at line 59 of file CesiumSampleHeightMostDetailedAsyncAction.h.
