UCesiumPrimitiveMetadataBlueprintLibrary Class Reference
#include <CesiumPrimitiveMetadata.h>
Inheritance diagram for UCesiumPrimitiveMetadataBlueprintLibrary:
static const FCesiumPrimitiveMetadata & GetPrimitiveMetadata (const UPrimitiveComponent *component)
 Gets the primitive metadata of a glTF primitive component.
static const TArray< int64 > & GetPropertyTextureIndices (UPARAM(ref) const FCesiumPrimitiveMetadata &PrimitiveMetadata)
 Get the indices of the property textures that are associated with the primitive.
static const TArray< FCesiumPropertyAttribute > & GetPropertyAttributes (UPARAM(ref) const FCesiumPrimitiveMetadata &PrimitiveMetadata)
 Get the property attributes that are associated with the primitive.
static PRAGMA_DISABLE_DEPRECATION_WARNINGS const TArray< int64 > & GetPropertyAttributeIndices (UPARAM(ref) const FCesiumPrimitiveMetadata &PrimitiveMetadata)
 Get the indices of the property attributes that are associated with the primitive.
Definition at line 58 of file CesiumPrimitiveMetadata.h.
◆ GetPrimitiveMetadata()
static const FCesiumPrimitiveMetadata & UCesiumPrimitiveMetadataBlueprintLibrary::GetPrimitiveMetadata ( const UPrimitiveComponent * component)
static
If component is not a Cesium glTF primitive component, the returned metadata is empty.
◆ GetPropertyAttributeIndices()
static PRAGMA_DISABLE_DEPRECATION_WARNINGS const TArray< int64 > & UCesiumPrimitiveMetadataBlueprintLibrary::GetPropertyAttributeIndices ( UPARAM(ref) const FCesiumPrimitiveMetadata & PrimitiveMetadata)
static
◆ GetPropertyAttributes()
static const TArray< FCesiumPropertyAttribute > & UCesiumPrimitiveMetadataBlueprintLibrary::GetPropertyAttributes ( UPARAM(ref) const FCesiumPrimitiveMetadata & PrimitiveMetadata)
static
◆ GetPropertyTextureIndices()
static const TArray< int64 > & UCesiumPrimitiveMetadataBlueprintLibrary::GetPropertyTextureIndices ( UPARAM(ref) const FCesiumPrimitiveMetadata & PrimitiveMetadata)
static
This can be used to retrieve the actual property textures from the model's FCesiumModelMetadata.
