UCesiumGeoJsonFeatureBlueprintLibrary Class Reference
#include <CesiumGeoJsonObject.h>
Inheritance diagram for UCesiumGeoJsonFeatureBlueprintLibrary:
static ECesiumGeoJsonFeatureIdType GetIdType (const FCesiumGeoJsonFeature &InFeature)
 Returns true if this feature's.
static int64 GetIdAsInteger (const FCesiumGeoJsonFeature &InFeature)
 Returns the ID of the provided feature, or -1 if no ID was present or if the ID is not an integer.
static FString GetIdAsString (const FCesiumGeoJsonFeature &InFeature)
 Returns the ID of the provided feature, or an empty string if no ID was present.
static FJsonObjectWrapper GetProperties (const FCesiumGeoJsonFeature &InFeature)
 Obtains the properties attached to this feature, if any.
static FCesiumGeoJsonObject GetGeometry (const FCesiumGeoJsonFeature &InFeature)
 Obtains the FCesiumGeoJsonObject specified as the geometry of this feature, if any.
static bool IsValid (const FCesiumGeoJsonFeature &InFeature)
 Checks if this FCesiumGeoJsonFeature is valid or not.
Definition at line 117 of file CesiumGeoJsonObject.h.
◆ GetGeometry()
static FCesiumGeoJsonObject UCesiumGeoJsonFeatureBlueprintLibrary::GetGeometry ( const FCesiumGeoJsonFeature & InFeature)
static
◆ GetIdAsInteger()
static int64 UCesiumGeoJsonFeatureBlueprintLibrary::GetIdAsInteger ( const FCesiumGeoJsonFeature & InFeature)
static
◆ GetIdAsString()
static FString UCesiumGeoJsonFeatureBlueprintLibrary::GetIdAsString ( const FCesiumGeoJsonFeature & InFeature)
static
If the ID is an integer, it will be converted to a string.
◆ GetIdType()
static ECesiumGeoJsonFeatureIdType UCesiumGeoJsonFeatureBlueprintLibrary::GetIdType ( const FCesiumGeoJsonFeature & InFeature)
static
◆ GetProperties()
static FJsonObjectWrapper UCesiumGeoJsonFeatureBlueprintLibrary::GetProperties ( const FCesiumGeoJsonFeature & InFeature)
static
◆ IsValid()
static bool UCesiumGeoJsonFeatureBlueprintLibrary::IsValid ( const FCesiumGeoJsonFeature & InFeature)
static
