Cesium for Unity 1.26.1
CesiumForUnity.CesiumMetadataValueType Struct Reference
Represents the value type of a metadata value or property, akin to the property types in EXT_structural_metadata. More...
 CesiumMetadataValueType (CesiumMetadataType type, CesiumMetadataComponentType componentType, bool isArray)
 Constructs a metadata value type from the given parameters.
static CesiumMetadataValueType GetValueType (System.Object inObject)
 The type of the metadata property or value.
 The component of the metadata property or value.
bool isArray
 Whether or not this represents an array containing elements of the specified types.
Definition at line 48 of file CesiumMetadataValueType.cs.
◆ CesiumMetadataValueType()
CesiumForUnity.CesiumMetadataValueType.CesiumMetadataValueType ( CesiumMetadataType type,
bool isArray )
typeThe type of the metadata property or value.
componentTypeThe component type of the metadata property or value.
isArrayWhether or not the property or value is an array.
Definition at line 76 of file CesiumMetadataValueType.cs.
◆ GetValueType()
static CesiumMetadataValueType CesiumForUnity.CesiumMetadataValueType.GetValueType ( System.Object inObject)
inlinestatic
Definition at line 86 of file CesiumMetadataValueType.cs.
◆ componentType
CesiumMetadataComponentType CesiumForUnity.CesiumMetadataValueType.componentType
Only applies when the type is a Scalar, VecN, or MatN type.
Definition at line 60 of file CesiumMetadataValueType.cs.
◆ isArray
bool CesiumForUnity.CesiumMetadataValueType.isArray
Definition at line 66 of file CesiumMetadataValueType.cs.
◆ type
CesiumMetadataType CesiumForUnity.CesiumMetadataValueType.type
Definition at line 54 of file CesiumMetadataValueType.cs.
